Originally Posted by M.L.S.C.
IIRC you're supposed to be seeing at least 1 pint of fuel for 10 seconds of cranking, so at 3 ounces per 5 seconds you're like 10 ounces short of that - I didn't see a lift pump in your list of replaced parts, and since that's what delivers the fuel to the injection pump that would be my prime suspect too.
That is correct I have not replaced the lift pump, as I thought It was putting out enough fuel, I will double check the pump output for the above volumes and repost the results, thank you.
