After installing my V3, found the pump was blowing fuses. Jason told me to take the pump off and check the gears for debris. Nothing in the gears so I put the pump back on. Blew fuses again. Loosened the mounting bolts for the pump a little bit and the pump worked OK. A day or two later, tightened bolts more and pump has been working ever since. - Patrick
