Originally Posted by lcotelaw
Hey - I'm trying to remove the rear brake drum on my 1993 f250. I've backed off the adjuster and it still won't budge. The local library doesn't have a manual for the truck. but a friend told me the axle has to come out. I thought that was only on older models. Shouldn't the drum come off? What am I missing. Thanks. Larry
The drum is probably rusted to the hub along with the wheel studs. Get some liquid wrench and spray the area and hit the drum with a hammer wail a while and then repeat. If you have the shoes backed off enough sooner or later it should come off, and you do not have to remove the axle.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
