Diesel Forum - TheDieselStop.com - View Single Post - HHO Hydrogen Conversions...
Old 08-04-2008, 12:45 AM   #12 (permalink)
drcampbell
My Photos: (5)
Originally Posted by xero-xero View Post
metered flow is an issue, but as far as internals, run it with gas, no problems, run it strait (yes it has been done) then you need a coating on all parts exposed the the combustion (ceramic, chrome, or titanium)
This is wacky. When running an engine at the same power setting on different fuels, cylinder pressure & temperature will also be the same.
If the cylinder pressure were higher, the engine would be developing more torque. And since cylinder pressure is a result of cylinder temperature, the same pressure is the result of the same temperature.
If the metallurgy is sufficient for gasoline or Diesel fuel, it'll be sufficient for any other fuel at the same power settings.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
drcampbell is offline
