Test resistance across the two terminals to test. Good should be about 1 ohm or so. If you have resistance, see if you have voltage at the connector with the ac on.
If there is no voltage there, then you have a bad switch, or low freon (or bad wire, etc.). If open circuit across terminals, then bad clutch. If there is voltage and resistance, the clutch itself may be bad. It might be possible to readjust, although it's probably shot.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
