I have this big puddle of fuel in the valley of the engine that runs down on the ground at the transmission or back of engine. I also have a leak back at the duel fuel tank switching valve. The rubber fuel lines look like they are special made from the factory with clamps I have never seen before so where do you get them? I am getting air in the lines that causes the truck to almost stall going up hills even with my foot to the floor. Has anyone replaced these lines back at the tank and the switching valve? Will the tanks need to be drained? I just filled both fuel tanks right before the truck started acting up so I have about 30 or more gallons of fuel on board. I have a 1995 7.3 Power Stroke.
Originally Posted by Drock96
i have a fuel leak, it is coming out of the bottom of the fuel filter i believe... or it looks like it is at least... Could this be the same thing as what your referring to?
