So far I have about 250 miles on 50-66% WMO in my 6.9 IDI, seems to run better than on #2 diesel. I do have the heavy gagging smoke at startup/idle.
I had one scary moment where I was accelerating from a stop and all of a sudden the engine seemed to be struggling, and my EGT was up about 200 degrees from the maximum I usually see, but after easing off throttle for 10-15 seconds the EGT dropped back to normal and the usual level of power seemed to return. Has anyone else experienced anything like this? Maybe the blend is settling in the fuel tank?
Where are you guys finding 2 micron water filters? At Menards and TSC where I have purchased filters, they lowest they have is a 5 micron.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
