Diesel Forum - TheDieselStop.com - View Single Post - You be the judge/jury - HPOP/ICP - which one is guilty?
Old 08-28-2008, 12:46 PM   #5 (permalink)
action4478
Originally Posted by bluenavigator View Post
Put ICP back in and used next port after ICP port. Can see the difference. The results are different as I recorded them.
Results:
600 rpm - 500 PSI (started from cold)
1000 rpm - 1400 PSI
1500 rpm - 1400 PSI
2000 rpm - 1400 PSI
2500 rpm - 1500 PSI
3000 rpm - 1600 PSI
fall back to 600 rpm, it stays at 1400 PSI. As I rev'd all ranges, it only ranges from 1400 PSI to 1600 PSI. Back to idling, it could go back to 1100 PSI. Seem that it goes all over the place in range of 1000's PSI. So what does that tell you?
Injectors may not need all the built up pressure ?..
What problem are you having?..
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline   Reply With Quote
