Originally Posted by wizbangdoodle
Nice. Did you bring the lines in through the back of the cab and under the carpet? How did you route them up to the console? Are they still visible?
The lines went straight down through a 3/4" hole in the floor (Installed Grommet). Routed the lines between the body and insulation that is around the transmission, then to the frame rail to the compressor. No lines are visible since they are inside and below the box. Be careful if you do something similar since there is a wiring harness beneath the console that you surely want to avoid. Pulling the seats and console will take about 10-15 minutes total to make sure you drill in a place that doesn't cause you stress later. Total installation was about two hours. I recognize by the picture that I should have moved the blue microfiber towel so you could see how clean the install is. If I get a moment, I'll take more pictures with the console cleaned out.
2008 Ford F350 Long Bed
White/Pueblo Gold Accent
Lariet, Automatic
Loaded, w/exc. to Navigation
Skyjacker 6" Lift and Steering Stabilizer
Toyo 37"x13.5-20 MTs
Eagle Alloy Chrome 114s
Amp Research Electric Steps
