Diesel Forum - TheDieselStop.com - View Single Post - You be the judge/jury - HPOP/ICP - which one is guilty?
Old 08-29-2008, 02:34 AM   #10 (permalink)
bluenavigator
bluenavigator's Avatar
My Photos: (5)
Originally Posted by action4478 View Post
Unplug the connector & look at it ,,,it should be dry....
A faulty ICP sensor can mimmic CPS symptoms ,,,
so can the small relays in the distribution box ....
Checked ICP sensor and it is clean and dry. Will check relays in daytime. Are these relays in the cab or in engine area?
Bluenavigator
'95 F-350 XLT PSD, CC, 2WD, Garrett Turbo AR 1.1, 5spd ZF tranny, LUK, 4.10 Limited Slip, just added Dual Arm Tenisoner. Just added my ol' vacuum gauge to monitor my vacuum pump.
bluenavigator is offline   Reply With Quote
