Diesel Forum - TheDieselStop.com - View Single Post - how to tell if my turbo is working properly??
Old 09-03-2008, 10:09 PM   #2 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Welcome to TheDieselStop
If you have a 0-30 psi gauge you can plumb in temporarily, you should see 15 psi or so when pulling a steep hill with the pedal to the floor. That's about all a stock PSD will do for boost.
Hard or no-start? Check Here
