Diesel Forum - TheDieselStop.com - View Single Post - ZF tranny problem
Old 09-03-2008, 11:13 PM   #2 (permalink)
johndeerebones
johndeerebones's Avatar
Originally Posted by mohead1 View Post
Was trying to change out the trans fluid in the 5-speed, and couldnt get the filler plug out. Ended up stripping it, and had to tear it up with a chisel to get it free and back it out. Dont know why the heck it was in so dam tight, the drain was so tight had to use an impact to get it out. ANYWAY, where the heck do I get a new filler plug? It is a straight thread with a flange that seals to the tranny. Dorman make replacements or it this a friggin dealer thing? Any help appreciated. I Tig welded a nut to it, and tried to fix the torn up flange so I can at least drive the truck, but its leaking already.
Grease a pipe tap up real goo and tap it out and put a pipe lug in it. The reason they stick so bad is that the dissimilar metals becomes a corrosion point. They can be a real pain to get out as you have seen. Another way is to get the drain out like you did and fill it through the shifter. capacity is 3.8 qts I think. Most people claim better operation with a rounded off 4 qts. You have to fill through the shifter for that.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline   Reply With Quote
