https://www.woodhouse.com/store/sleeper_berth.htm
Woodhouse Sleeper Berth (Patent Pending)
• • • DOT Compliant • • •
Finally, a low cost DOT Compliant sleeper berth exclusively for 1-ton pickup haulers. The Woodhouse Sleeper Berth eliminates driver's concerns over DOT sleeping requirements and keeps drivers on the road with a better nights sleep.
Details
• Available for 2003 and newer Dodge Quad Cab 1-ton trucks
• Available for 2006 and newer Dodge Mega Cab 1-ton trucks
• Available for 1999 and newer Ford F350 Crew Cab 1-ton trucks
• Only Sleeper Berth available without modifying the vehicle frame or cab
• No outside appearance changes
• Vehicle can be restored back to original configuration and appearance in hours
• One year component failure replacement warranty
• The perfect legal solution for the Hot Shot Operator
• Can be converted into existing vehicle or
financed into a New/Used Vehicle Purchase
• Eliminates costly motel charges
• Eliminates DOT violations
Specifications
• Compliant w/ DOT Regulation 49 CFR 393.76
• Innerspring Mattress measures 76" x 26" x 6" (DOT requires at least 75"x 24")
• Restraint system tested and exceeds the required 6,000 lb restraint Pull-Test
Restraint system manufactured exclusively for the Woodhouse Sleeper Berth by Indiana Mills and Manufacturing, Inc., an industry leader in cargo harness restraint systems.
How to get one?
Call or email Jeff Mabry or Ron Blankenship. This conversion can be installed in less than one day by our professional staff at the Woodhouse Truck Center, your centrally located 1-ton diesel experts.
