Diesel Forum - TheDieselStop.com - View Single Post - Attention Crew Cab Sleeper Owners!
Old 09-04-2008, 08:26 PM   #3 (permalink)
MarkEkberg
MarkEkberg's Avatar
My Photos: (13)
That has been debated before. Too bad they need to do things like that. We have a 00 and a 06 crew that we sleep in all the time. DOT never questions it. If they were to ever ask if you slept there just say no.
You do not have to prove where you rested, only that you did.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline   Reply With Quote
