Diesel Forum - TheDieselStop.com - View Single Post - Large Fuel Leak
Thread: Large Fuel Leak
Old 09-04-2008, 08:35 PM   #1 (permalink)
KKSC
Large Fuel Leak
I have an issue that is probably pretty common, but I'd like to make sure I'm heading down the right road with fixing it.
I have just moved to Eielson AFB, Alaska from Mountain Home, Idaho. My truck (2000 F-250 PSD) was shipped from Tacoma, Washington. Shortly after it arrived here it started to drip fuel out of the drain valve tube. I followed the line back to the valve and it looked like it might be slightly opened. I ensured that it was closed all of the way and went ahead and changed the filter in case it may have been fouled. The next day I had the same issue. The AFB kind of frowns on having fuel leaked all over their driveways so I decided to put a rubber vacuum line plug over the end of the line since I figured (wrong) that it wasn't pressurized. Today when I drove it to work and parked it I had fuel streaming out of the tube and on to the ground. When I turned the key to the "ON" position it started gushing fuel, and now does it everytime I turn the key.
I'm hoping all I have to do is replace the valve and that will fix my problems.
I did a search on the forum and found the thread to replace the o-rings, but I don't currently have the time or the place to rebuild the valve.
Hopefully I'm heading in the right direction with the quick fix. Does anyone know of any other options?
Kevin
2000 F-250 7.3 PSD
KKSC is offline   Reply With Quote
