Diesel Forum - TheDieselStop.com - View Single Post - Re-sealing my engine. Is it worth it?
Old 09-05-2008, 07:27 AM   #4 (permalink)
MarkEkberg
MarkEkberg's Avatar
My Photos: (13)
I have friends that seem to think they can have the motor out in 2-3 hours. I know I don't work that fast, but it looks like it could be done in a long weekend with a helper or two?
I have run AMSOIL since I bought it with 75K. I am leaking about a quart (best guess) every 1000 miles. I hate to see money like that go on the ground. Maybe I should switch back to Rotella and not worry about it, but I have gotten into the groove of not changing the oil. That will be hard to overcome.
I will have to see what my potential helpers say. I have other cars to drive if nothing goes right.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline   Reply With Quote
