Diesel Forum - TheDieselStop.com - View Single Post - You be the judge/jury - HPOP/ICP - which one is guilty?
Old 09-05-2008, 10:31 PM   #20 (permalink)
bluenavigator
bluenavigator's Avatar
My Photos: (5)
Originally Posted by bigred350 View Post
This sounds a little like the problem I am having with my truck. I do not get A cel light. I have changed the injector o-rings and installed a new ipr. no help on the ilde I am suspecting the icp but do not what to keep putiing parts on it and having no help. When I pull my connector on my icp my engine dies? any way to test this sensor? I need help to.
Look at the first post (look below) that I posted. My engine was running without ICP, not dying at all. The ICP was sitting on my shop bench. It does give out HPOP pressure measurements. Actually, what was happening, the controller was guessing the pressures and give out voltages.
Originally Posted by bluenavigator View Post
Somehow, I was so busy and didn't get chance to redo the diagnios on my truck. I had posted the issue on my truck. Armed with new oil pressure gauge, I pulled ICP out and put the oil pressure gauge in the ICP's hole. I changed the oil. The oil was ruined with brake fiuld that I accidently poured in the engine. I drained and left it draining all the day. The oil stopped dripping, leaving strange gummy oil - bad oil or that was result of adding brake fuild to the engine oil? I just hope that 1/2 cup of brake fuild doesn't have much effect on the engine. Anyway, I recharged the batteries since the truck wasn't started over 2 months. The engine started on first try, which is good news. I watched the high oil pressure gauge as I rev'd the engine. I recorded the results.
The results:
600 rpm - 600~650 PSI <--- idling speed
1000 rpm - 650~700 PSI
1500 rpm - 700 PSI steady
2000 rpm - 800 PSI steady
2500 rpm - 1100~1250 PSI (tried to keep engine reving steady)
3000 rpm - 1400 PSI (able to hold the engine reving steady)
Are the results good? The ICP is out of the engine and sitting on the work bench in my garage. Pretty much that it tells you that ICP isn't plugged in the system. Do I need to retest this with ICP out but plugged in the system? Let me know which part is the guilty party.
Anyway, I guess that I will check all the wirings from ICP sensor plug to the harness and follow it to the end. It should lead to the engine controller module, right? If not, where should the ICP sensor harness lead to then? IDM?
Bluenavigator
'95 F-350 XLT PSD, CC, 2WD, Garrett Turbo AR 1.1, 5spd ZF tranny, LUK, 4.10 Limited Slip, just added Dual Arm Tenisoner. Just added my ol' vacuum gauge to monitor my vacuum pump.
bluenavigator is offline   Reply With Quote
