I'll comment on this one. I'll be second to say that all but Frybrid and Vegistroke/DFA are all crap, as far as I have seen and heard. Dad has a Vegistroke on his truck, an early version, which has had some issues but in the end has gotten him 75,000 miles on vegetable oil. Sounds like now the bugs we have had to deal with (electrical problems, pump failures) are pretty much sorted out. Spend the money now, and you won't regret it later. If you try to build your own, you'll probably spend more, and definately way more time, and not have as good a system in the end. The lovecrap or any other system will, at the end of the day, feed your motor with at least some cold oil and you will eventually suffer the effects of accelerated engine wear. My $0.02.
1994 F-350 CC LB SRW 4x4 5 spd. manual. Homebuilt vegetable oil fuel system coming soon installed. 253k, 1k on vegoil.
Dads truck - 1997 F-350 CC LB SRW 4x4 5 spd. manual. Stock except for the vegistroke fuel system, over 90k on WVO. 230k on the truck.
