Diesel Forum - TheDieselStop.com - View Single Post - Hydroboost install done!! I guess I'll try a Parachute!!
Old 09-17-2008, 09:28 PM   #1 (permalink)
DIESELDUTTON
DIESELDUTTON's Avatar
I just completed my hydroboost install, it took me longer to locate the spring and push rod then it took to install. I ended up buying a complete hydroboost from a junk yard from a 03 Super Duty just for the push rod and I guess I can use it for a core. The pedal feels great, maybe a little to firm, but much better then before, but I believe my truck stops worse then it did before. Then I thought maybe the spool valve has to move a certain distance before it routes the high pressure oil to where it needs to go so I spaced the master cylinder about 1\2" from the booster to see if that would help and it helped a little, now the pedal moves about 3\4" before it gets firm. Does anyone know how a hydroboost unit works? I dont know what else to do, I have 4 wheel disc, every brake line on the entire truck has been replaced, RABS valve is bypassed, 4 wheel disc master cylinder, all rotors, pads and calipers were replaced last year when I did the Dana 60 install. My power steering pump is about 1 year old, the Bendix master cylinder was new last year and the hydro boost is a remanufactured unit from Cardone. What am I missing? Thanks guys
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline   Reply With Quote
