Diesel Forum - TheDieselStop.com - View Single Post - Excessive smoke with wmo
Old 09-19-2008, 09:54 AM   #4 (permalink)
jski55
Originally Posted by edub32 View Post
I'm running about a 85% wmo (5 micron) diesel right now and for some reason lately ive been starting to get a lot of blue smoke. at 65 in OD it seems to clear up but at starting and medium speeds theres quite a bit. should i premix before pouring into tank or am i running to "rich" of a mixture.
Sounds like you are running too thick a mix. I have run 100% wmo with no more noticeable smoke but the ambient temp was high. Meaning it was hot outside.
I now run in the 80 to 85% range. Is your source actually wmo or some blend of that? Sometimes people get a blend of used oils with different weights and i have noticed a difference there.
I run a heat exchanger so it affects me a little less than most. And I test my mix with a hydrometer so that its near or the same as #2. Bio-Diesel: Farm Grown Profit will help you with that.
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline   Reply With Quote
