Diesel Forum - TheDieselStop.com - View Single Post - Installed my bypass filter today..PICS!!
Old 09-22-2008, 11:31 PM   #19 (permalink)
MT56POWERSTROKE
Oil return line
I really like your setup. I have a high flow crankcase ventilator that goes from my intake to the oil fill cap and could use a setup like you have here with the ccv and not have to sacrafice either one. I would like to know where you got these parts so I could do the same. I have an Amsoil bypass kit but have not installed it yet since I do not want to drill holes in the oil pan. One more question.
My intake is a little off and I cant get the oem ccv tube to fit, so I have a piece I cut on there but its totally kinked and probably closed off inside. Can this cause any damage to the engine if that is blocked. I need to find a flexible type of tubing that will not kink and not have a memory so I can bend it and hook it up the right way. Please let me know. Thanks
2001 Black Ford Excursion 7.3 PSD 4x4 Limited
Jobe Performance Intake
Edge Evolution with BD tunes for the 7.3 Powerstroke
2-4 inch lift with 33x12.5 BFG All Terrains
Schaeffer's 5w-40 series 9000 synthetic
Amsoil synthetic ATF in tranny and transfer case
Amsoil severe gear in diffs
Amsoil Ea oil filter
Amsoil single bypass filter kit
BD Xhale stainless 4 inch turbo back
50watt HID in fog lights, holy crap they are bright!!
I love my Excursion
MT56POWERSTROKE is offline   Reply With Quote
