Diesel Forum - TheDieselStop.com - View Single Post - 96 PSD WVO Kit Install and ?
Old 09-24-2008, 10:28 AM   #2 (permalink)
hheynow
hheynow's Avatar
I've had the Plantdrive kit in my '97 for 2.5 years and 25K WVO miles. It uses the stock fuel pump for each fuel but has separate filters. No issues with the fuel pump and actually it performs flawlessly. The biggest downside is using a 6 port Pollak valve which so many trash talk because of its failure rate and cross contamination. Mine has been 100% trouble free and a squirt of WVO in my (bio)diesel tank per purge is no big deal because I always run my (bio)diesel tank to the red line before refilling which prevents a WVO build up which would occur if I only topped it off every few days.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline   Reply With Quote
