...and AFTER you return it to stock, you must disconnect BOTH batteries for about 5 minutes and turn the headlights on.
You need to completely discharge the capacitors that can store the evidence of the reprogramming.
Its a good idea to keep the tuner in the truck, so if something happens when you're far from home, you can still return the truck to stock.
The SCT with Innovatives tunes is an awesome improvement over stock.
You'll be pleased!
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 W/eXtreme tunes from Innovative,
but staying stock for now!
ARP studs installed-and new heads
EGR cooler FIXED for good!
Sneaky sneaky!
Coolant Filter
MBRP 4" Turbo Back
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
FICM REPAIR MOD
Upfitters w/ high-idle mod
40 gal aux fuel tank
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
Jimmi Jammers
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Grover Emergency Air Horns
Viair 200psi air system
Bed cover
