Diesel Forum - TheDieselStop.com - View Single Post - Conversion Kit Recommendations
Old 09-26-2008, 05:37 AM   #20 (permalink)
MongoVB
The golden system has built in heat exchangers in thier tanks and heated filters available. They are also set up for dual tank systems. So why couldnt you have 2 tanks one clean one dirty then run the output of the dirty tank through the first heated filter into the centrifuge then into the clean tank? The tanks also have an 8" access hole you could probably drop in some bag filters for when you pump in the oil. Does that make sense? Just for the record, I have no ties with the Golden system, I just like the thought they put into thier tank design. Also, How long does it take before the oil is warm enough for use? I'm guessing it wouldnt be worth it if you are just doing short trips around town unless you live in a warm area.
2002 F250 7.3
DP Tuner chip
4" Dynomax Exhaust straight piped
305/16 Toyo Open Country AT's
MongoVB is offline   Reply With Quote
