Yes sir, Waste Motor Oil (WMO) and auto trannie fluid along with other petrolium products will run in a diesel engine. You have the 6.0 and I have heard mixed results with it due to the weak fuel system. I have been running WMO and Diesel mix at 50%/50% and even up to 75%/25% with NO problems. The best my truck runs is on 50/50 with #2 diesel, when I run ULSD by itself I can tell a difference in how my truck runs, louder and dont pull as strong. Do a search on WMO and you will come across some interesting stuff.
2001 F250 4x4 long bed extra cab 6 speed hand shaker . DIY Tymar, 4" turbo back straight pipe w/ 5" stainless tip, DP tuner F5 w/ stock, high idle 1200 rpms, 60hp tow, 80hp econo and 120hp performance. Auto meter Boost and EGT gauges on an A pillar pod. 203* thermostate. BRV+, CCV mod run to the back between fuel tank and skid plate. 2.5" leveling kit and running 315/75/16 Hankook MT. Cobra CB with dual 3' whips. 12000 miles + on WMO and ZERO problems.
Huge make over on the way.
6.5 Procomp lift, 20" Motos wraped with 37x12.5 Procomp Rubber.
Soon to follow. Ranch hand bumpers, GT38R turbo, High performance HPOP, Head studs, 6" miter cut stacks.
