Diesel Forum - TheDieselStop.com - View Single Post - Conversion Kit Recommendations
Old 09-26-2008, 08:50 AM   #21 (permalink)
ToddT
My Photos: (6)
We are getting off topic here but I wouldn't run a centrifuge while cruising down the road. It needs to be open to the air for the water vapors to escape. And, it does splash a bit. But.... it 'could' work. As far as I can tell, Golden does not include a centrifuge.
The general consensus of the veg oil community says there are two main ways to get water out of veggie: heat,filter and settle OR heat and centrifuge/flash off.
With that said, you could theoretically have a heated and filtered 'clean' tank with a substantial water trap (holding tank) on the bottom. And, if you drained that tank prior to movement in the morning... it might work.
ToddT is offline   Reply With Quote
