New Drain Valve Assy.
Just tore into my 96 this evening with new drain valve kit. Got too dark so had to retire. Pump under turbo was replaced last year. Still leaks. Looks like the bowl definitely has to come loose. I AM NOT A DIESEL MECHANIC. I know there is air in the lines now worrying about the first start up attempt. The fuel lines I've looked at on the truck look to be in bad shape. This has been a very helpful reading, thanks very much. Any pearls of wisdom on whatever else may leak in there? All lines and o ring will be replaced, I only want to do this once every twelve years or so. Thanks again -Pat
