The wastegate will not affect your shifting. It you set a turbomaster to say 25lbs, it doesn't start to open until that point and it bleeding off any excess boost so that it stays at 25. If you are at say the max boost you set, again 25 psi and shift, it would close the wastegate if boost drops below 25 psi.
The only issue you may have is with your MAP sensor if you don't have a boost fooler.
I have floored it racing and hit 35 psi and when I let off, the only thing you hear is excess air being expelled out the air intake.
