Diesel Forum - TheDieselStop.com - View Single Post - Fix your fuel leak from filter drain valve
Old 09-27-2008, 06:37 PM   #45 (permalink)
Window&Door
Window&Door's Avatar
Replaced drain valve and o rings, cleaned and dried valley pan well. Still leaks. I bought a distribution pump with new washers and all new fuel lines. I'll check the pump replaced by the Ford Stealership. Looks like I will need to yank the turbo so I'm going to wait till I got the money for a 1.00 Turbine Housing and a better compressor wheel. I'll do the HPX while I'm at it long with a fuel pressure shim and gauge. There's really not a whole lot that can leak into the valley pan when you think about it, there's hoses and O rings but that's it. Not quite as difficult to work on as it is intimidating. Reading and pictures help. Anyone know of a good manual to get? I have a chilton, but it sucks for the powertrain on a diesel, great for chassis and brakes.
Window&Door is offline   Reply With Quote
