Diesel Forum - TheDieselStop.com - View Single Post - Hydroboost install done!! I guess I'll try a Parachute!!
Old 09-29-2008, 09:13 PM   #5 (permalink)
DIESELDUTTON
DIESELDUTTON's Avatar
Originally Posted by Stock Stroke View Post
what did you guys do about the stock vacuum pump?
I didnt do anything with mine, I just removed the line going to the booster and capped it at the plastic manifold. If the pump goes bad again I might look into a electric pump to run the heat\- a\c. I removed my F-S\D master cylinder and installed my stock (smaller bore) master cylinder and my brakes got a little better, but by no means are they stopping my truck the wat they should be. This is the worst stopping car or truck I have ever owned. I dont know if I have the wrong compound pads on or what, I had napa brand severe duty pads on the front and the stock pads that Blackbirds ships with there rear disc kit. Then I switched to a cheaper softer front pad and a better set for the rear and the brakes still suck, so I figured I would install the hydro boost (4 times more power) now I have to really stand on the pedal. I dont know how much pressure I have at the calipers but all of the brakes are 250* when I come back from a test drive. I spoke to a tech at Cardone and he said the power steering pump is fine the pressure is made in the steering gear, I dont understand, the hp hose goes to the hydro boost first and then to the steering box. I have had just about enough of this braking system. Thanks guys
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline   Reply With Quote
