Diesel Forum - TheDieselStop.com - View Single Post - Fix your fuel leak from filter drain valve
Old 10-04-2008, 07:54 PM   #47 (permalink)
bugman
bugman's Avatar
My Photos: (18)
You will get more and faster help if you post down in the regular forums. As far as the leak yes you can replace the sensor or if you would like just remove it and put a pipe plug in its place. If you plug it off just remember to drain the housing every now and then to keep water out of the injectors.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline   Reply With Quote
