Diesel Forum - TheDieselStop.com - View Single Post - Hydroboost install done!! I guess I'll try a Parachute!!
Old 10-05-2008, 12:59 PM   #14 (permalink)
DIESELDUTTON
DIESELDUTTON's Avatar
Originally Posted by Haz Tanker View Post
Forgive me for asking this if you have done it or it doesn't matter but did you use the power steering pump to go with the hydraboost? I would think if the pump were doing more than just steering duty it would need a higher flow rate to work properly.
Thats what I was thinking, but I called A-1 Cardone and spoke to a tech and he said my pump is fine, then he told me the pump only makes 400-500 psi and the steering box\gear makes the pressure, now I dont know enough to know if he is giving me the proper information. I do know that since the hydro-boost install, my pump makes noise at idle. Thanks
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline   Reply With Quote
