Originally Posted by DIESELDUTTON
Thats what I was thinking, but I called A-1 Cardone and spoke to a tech and he said my pump is fine, then he told me the pump only makes 400-500 psi and the steering box\gear makes the pressure, now I dont know enough to know if he is giving me the proper information. I do know that since the hydro-boost install, my pump makes noise at idle. Thanks
Frank
that tech is fos--if you nearly blocked of the pressure outlet--and had a gauge on it, it should put out a max of around 1050 psi---the steering gear just produces resistance when you turn-----if you turn the steering wheel to full lock---hear the squeal????? thats the pressure valve bleeding off---if you dont hear it--the pump is wearing out--or already has---and if thats the case--no wonder no brakes---i/e no pressure in the reservoir on the brake assm---
