Diesel Forum - TheDieselStop.com - View Single Post - Hydroboost install done!! I guess I'll try a Parachute!!
Old 10-05-2008, 07:09 PM   #19 (permalink)
DIESELDUTTON
DIESELDUTTON's Avatar
Thanks for the info guys, I did put a reman pump and steering box in a year or so ago, just because I messed with the screw on top of the box only to find out it was my u-joints in my axle so I guess it was more like two years ago when I replaced the box and pump. Now that I think about it, the 97 250 at work turns alot easier then my truck does, even before the 35's. Thanks for the idea's.
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline   Reply With Quote
