On that beast I would be more worried about the Tires /Brakes than anything else. Also the front end is of major concern like ball joints / tire rods . If it is an IDI I would test the compression to see where you stand. If it is OK then go for it . IDI's are very reliable and easy / cheap to fix compared to powerstrokes. Also the Transmission if it is a C6 and well taken care of is almost bulletproof. The one I have on my dump is one of those.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
