Diesel Forum - TheDieselStop.com - View Single Post - new clutch now grind noise?
Old 10-14-2008, 01:51 PM   #3 (permalink)
Justin C.
Justin C.'s Avatar
Did your setup get replaced with a single mass flywheel? If so that's the reason it's grinding, and it's normal. The dual mass flywheel absorbs some vibration and noise, but the single won't. That gives you the grinding sound at low RPMs. It won't hurt a thing, and most clutch manufacturers will include that in their literature. I've got a South Bend and it grinds pretty good at idle and lower RPMs.
Justin
Justin
1997 F-250 Power Stroke
- 230k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, BDP live tuned
2005 F-350 Power Stroke (work truck) - 220k
ARP Studs, PHP 40 hp flash
Justin C. is offline   Reply With Quote
