Diesel Forum - TheDieselStop.com - View Single Post - Excessive smoke with wmo
Old 10-15-2008, 09:25 AM   #9 (permalink)
skibarefoot
I run 50/50 mix. I mix first then filter down to 2 microns. Mine smokes at idle. The longer it idles the more it smokes. Once moving there is no smoke. Of course if you get on it or pulling hard it will smoke like on regular diesel.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
skibarefoot is offline   Reply With Quote
