Diesel Forum - TheDieselStop.com - View Single Post - Injector Problem?
Old 10-15-2008, 11:10 AM   #3 (permalink)
blaster1288
No... I never got a chance to.... But I'm not loosing coolant or oil... How common is low compression with out these symptoms
Brad
96 F-250 extended cab long bed, 5-speed, Luk clutch, 4x4, 4.10, 3" lift, 35x12.5 BF All-terrains, 3" down pipe, straight pipe, shimmed FPR with gauge, stage 1 injectors, Dp-Tuner F-5 80 econ. 1100 HI-Idle 100HP Performance, Gauge style switch, ISSPRO pyro and boost, water temp, oil pressure, SuperDuty starter. 193,000 and counting
blaster1288 is offline   Reply With Quote
