Originally Posted by dieseltrucker
Did you check fuel pressure? Also a new fuel filter and clean the return screen on the pressure regulator
Are there any fuel filter brands to stay away from? I bought a NAPA filter to put in it.
Is there a specific place to check the fuel pressure? Is there a schrader valve where I can hook up? What should the pressure be?
I will check out the pressure regulator screen. Can I just take that out and blow it clean?
The turbo fins looked good in the spring but I will check again.
Could this be injector related?
I did have the truck out yesterday in the rain and it will not spin the tires on wet pavement if that means anything lol.
