Diesel Forum - TheDieselStop.com - View Single Post - 95 PSD chugs on startup and low on power
Old 10-16-2008, 01:04 PM   #10 (permalink)
blageurt
blageurt's Avatar
NApa Filter is OK. I cleaned the screen with a Q tip soaked in carb cleaner. You might need a mirror to see it . It is inside the fuel filter assembly so you have to remove the filter to access it. It is on the other side of the FPR . There is a schreader valve on the filterbowl assembly at about 3 o'clock looking in the plan view. Pressure should be 50-60 @ WOT . If it is shimmed could be as high as 70 . Cranking it should be around 20-30 IIRC.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline   Reply With Quote
