Diesel Forum - TheDieselStop.com - View Single Post - 95 PSD chugs on startup and low on power
Old 10-16-2008, 05:09 PM   #11 (permalink)
MarkEkberg
MarkEkberg's Avatar
My Photos: (13)
There is a valve to check fuel pressure.
It should be at least 55-60 at idle. If it isn't your looking at a fuel pump.
You should test the PSI of the HPOP as well. You could have a cut o-ring that is bleeding off high pressure oil not allowing the injectors to fire right. I had that problem once.
Any check engine lights?
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline   Reply With Quote
