Diesel Forum - TheDieselStop.com - View Single Post - Injector Problem?
Old 10-18-2008, 05:43 AM   #6 (permalink)
Excavator
Excavator's Avatar
My Photos: (11)
Double check that glow plugs are with in spec and working and if all are good then you MAY have injector poppet valve ware and the cold oil will not let the poppet seats seal untill after a few minutes of warm up time.
This can be checked by using a feeler gauge to measure armature plate clearance on cold injector. If you want to further look at this let me know and I will give you more details on how to measure armature plate spec. The injectors can stay in engine but it involves pulling off valve covers and the removing the solenoids on top of each injector and using a feeler gauge to measure the gap between armature plate and injector base. I had the same problem on my black F250 and the engine would not start. I bought this truck as NON RUNNING from Ford lot and then I did all the basics such as glow plugs, relay,UVC gaskets and harness's and still had NO START. Dave over at SWAMP DIESEL PERFORMANCE educated me on the poppet seat problem on high milage injectors and showed me how to check the clearance on the armature plate. I had 5 injectors fail the spec and I elected to go with Swamps Performance BABY SWAMPS Injectors. Never looked back You should plug in the block heater one night and if it starts right up then you should look at the problem being the poppet seats only after you are 100% sure glow plugs and relay are good
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline   Reply With Quote
