Old 10-18-2008, 05:54 AM   #10 (permalink)
Excavator
Excavator's Avatar
My Photos: (11)
Originally Posted by DIESELDUTTON View Post
I have been using the DSE formula since spring (about 10,000 miles) so far so good. Good luck
Frank
Hi Frank
We both have had good results thus far.
I am running it thinner now in colder months and I have just started using a water heater element in a drum to warm up the oil before the prefiltering.
The heating up helps settle things faster to bottom of drum and then after a few days of setting I heat up again to about 140 degrees then pump it into my laundry bag prefilter. I have been running it in 3 Powerstrokes for about six months and this is nothing new for diesel engines. It is better known as thinning and blending and has been done for years. Diesel Secret is a way to get started in blending but it is not the only way to do it. Most call it a scam because they are making money. The system does work but the filtering is the most important part of this process. I run straight diesel in one tank and WVO on other and use straight diesel to start up on the COLD days untill engine warms up a bit. I also shut down on straight diesel if weater is cold but in summer months it is WVO full time
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 183000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline   Reply With Quote
