Listen to what Airfooter (jason) is telling you. I went for a GFS conversion just for the excursion tank (no one else was makin them then) and had to learn the hard way about how bad my system was plumbed. I relied on all of these guys on this forum and frybrids to get me back running again. It took 2 months of working a few hours every other night to get my truck plumbed the right way and its still not a vegistroke. Its good but not perfect. Spend the money up front on either a frybrid or vegie stroke. I would do some heavy looking into getting enough oil to go your200 mile a day habit. It is getting harder and harder to secure sources. Nothing worse than ivesting 4k into a system and then cant find any oil.
AJ
