Don't dare mix my 7.3L with a 6.9L.
No vote here.
I think it will only take a tread longer to get the answer you are looking for if it is combined.
When you have two seperate ones, it's more to the point.
IMHO...............
EARLY 99' F350 7.3 CC 4X4 LB. DRW. AUTOMETER BOOST, PYRO, TRANS TEMP, WATER TEMP, FUEL PRESSURE - AIS INTAKE - 4" SS MBRP TURBO BACK - JOHN WOOD TRANS - 6.0 TRANS COOLER - CCV MOD - DP TUNER STOCK, DECEL, 20T, 40T, 60T, 80E, 120 RACE - OPTIMA BATTERIES - SUPERLIFT FRONT-END LEVELING KIT - 35" BFG A/T - 2" REAR SPACERS - DUAL FRONT RANCHO RX9000 - UPGRADED POST 99' 10MM HUB ASSY'S - SLOTTED BRAKE ROTORS - ORU/MAG-HYTEC TRANS PAN & DIFFERENTIAL COVERS - ITP SS HP-X - ITP REGULATED RETURN - HEATER BYPASS VALVE - AIRDOG - DIESELSITE COOLANT FILTER - DIESELSITE 203* TS WITH BILLET HOUSING - AMSOIL DUAL BYPASS - DIESELSITE EXTERNAL TRANS FILTER - FUMOTO VALVE - DC PERF 190 AMP ALTERNAOR - TOW 37' 5ER WEEKEND WARRIOR 15K WET W/ALL THE TOYS ON BOARD.
<span style="color: blue">PIC OF MY RIG</span>
