Diesel Forum - TheDieselStop.com - View Single Post - Should the IDI forums be combined??
Old 10-27-2008, 07:33 PM   #25 (permalink)
7.3L F-250
7.3L F-250's Avatar
My Photos: (16)
Send a message via AIM to 7.3L F-250
Originally Posted by hesutton View Post
Nah......I disagree. Both the 6.9 and 7.3 can be found with the 10.25 rear axle, Dana 60 (F350) or Dana 44/50 (F250), ZF5, solid state glow plug system, C6 tranny, 1356 T-case. Also the 6.9 and 7.3 were found in the '87-'91 body styles. Wiring changes have to do with body style not engine size.
You cannot assume anything based on the displacment of the IDI in the truck. Signatures with truck info are vital reguardless if there are one or two forums.
Heath
theres more differnces then you think there are
the only 6.9 that had the zf-5 stock was the 1987 modle year and that was only untill the half way point (same with it being in the 87-89 style)
the entire glowplug wireing for the 6.9 and 7.3 are different
if you have a 90+ 7.3 you have the E4OD which the 6.9 never came with
the 6.9 manly had the T-19 4 speed while the 7.3 always came stock with the zf-5 (except the 99+ model years)
the T-19 uses a linkage system clutch insted of the zf-5 which uses a hydrolic clutch
like i said i vote no because it will get to confusing but if you do combine them we need more then 20 posts per page and make up to date signitures manditory
company trucks
2002 ford F-350 powerstroke cc sb zf-6
1987 ford F-350 6.9L idi flat bed
1989 ford F-350 7.3L idi pick up
CURRENT PROJECTS
1978 ford F-350 custom
7.3L F-250 is offline
