Diesel Forum - TheDieselStop.com - View Single Post - Gauge Trouble
Thread: Gauge Trouble
Old 11-02-2008, 11:30 AM   #2 (permalink)
OMCUSNR
Originally Posted by BlueJay View Post
I did a search and can not fine any info. on this problem that I'm having. Last week when I used my truck an 04 the "Check Gauge" light stayed on and the check engine light came on. As I drove the truck the trans. gauge did not move. I started the truck after making a stop the same thing happen with the gauge and lights. After about two miles the gauge started to work and the "Check Gauge" light went off. The next time I started the truck the engine light was off. I took the truck the the dealer at that time everything was ok. They said that the only reading they got was one from the fuel sending unit and could not fine anthing wrong. That was $139.05 later. Yesterday I drove the truck this time the Temp. gauge would not work for about the frist half hour. Has anybody had this problem, or can tell me what is going on???
Sounds like your dash instrument cluster is starting to have problems. Some guys have had their dash's replaced. The wiring may be shorting out. Not sure how much it'll cost to repair.
I'd start saveing for a set of real gauges, instead of the dash idiot lights.
OMC
OMCUSNR is offline   Reply With Quote
