Originally Posted by BlueJay
 I did a search and can not fine any info. on this problem that I'm having. Last week when I used my truck an 04 the "Check Gauger" light stayed on and the check engine light came on. As I drove the truck the trans. gauger did not move. I started the truck after making a stop the same thing happen with the gauger and lights. After about two miles the gauger started to work and the "Check Gauger" light went off. The next time I started the truck the engine light was off. I took the truck the the dealer at that time everything was OK. They said that the only reading they got was one from the fuel sending unit and could not fine anthing wrong. That was $139.05 later. Yesterday I drove the truck this time the Temp. gauger would not work for about the Frost half hour. Has anybody had this problem, or can tell me what is going on???
Just a suggestion but in some of the older models there were ground problems with the instrument cluster. It is nothing more than a large printed circuit board and probably is grounded in only one place. Have no idea where to look.
'05 F350 Lariat DRW 4X4 6L Auto, stock.
Above replaced '91 F350 XLT Lariat DRW 2X4 7.3L 5 speed man.
