Diesel Forum - TheDieselStop.com - View Single Post - Unloaded PSI in new tires?
Old 11-04-2008, 12:25 PM   #2 (permalink)
JW350
JW350's Avatar
My Photos: (29)
The tire inflation chart shows you the minimum pressure for a given load. If you have the weight of both your font and rear axles, use those to find the appropriate tire pressure on the chart for the front and rear wheels.
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, Fox Shox, 37x13.5x17 Toyo Open Country MT on Weld Evo Velociti XT, 4.88 Gears, MagnaFlow Exhaust, AMP Research PowerStep, Auto Meter Cobalt Gauges (EGT Boost Trans), ScanGaugeII, Firestone Air Bags/Compressor/Tank, BulletProofDiesel EGR Cooler, Valvoline lubricants, Final Charge Global ELC, DieselSite Coolant Filter
JW350 is offline   Reply With Quote
