Diesel Forum - TheDieselStop.com - View Single Post - AFE intake throwing trouble codes
Old 11-08-2008, 12:41 PM   #5 (permalink)
timid1
Originally Posted by APEX320 View Post
Make sure that when you install your instake system you reset the "FILTERMINDER" by pushing the button on the sensor as it WILL throw codes if you didnt, Make sure that you put in your stock intake if you take your truck to the dealership as it can void your warranty. Key word CAN.
Are you saying that those who install aftermarket intakes AND reset the filter minder will not get these codes?
I've read MANY posts here about different intakes throwing the exact same codes. Some how I think that the filter minder isn't going to make the problem go away.
My educated guess is that it's a problem with the intake and the tight parameters of the truck's on-board computer. Translation: there's squat you can do about it without going back to stock.
timid1 is offline   Reply With Quote
